Problem with hyperlink conversion with rvhtmlimport HTML2RVF
Darken
Post by Darken »
Hello Sergey!
I have proble with conversion HTML to RVF.
In html bellow you can see hypelink with format (italic, bold and set other color, font name). When convert from HTML to RVF hyperlink format is lost... :(
      RvHtmlImp := TRvHtmlImporter.Create(RVEdit);
      RvHtmlImp.RichView := RVEdit;
      RvHtmlImp.Encoding := rvhtmleANSI;
      RvHtmlImp.BasePath := ExtractFilePath(FileName);
      RvHtmlImp.Options := [rvhtmloAutoHyperlinks];
        SetLength(s, Stream.Size);
        Stream.ReadBuffer(PRVAnsiChar(s)^, Length(s));
        Stream.Free;
      RvHtmlImp.LoadHtml(s);
      RvHtmlImp.BasePath := '';
      rve.Modified := true;
      RVEdit.Format;
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html><head><title>htmlimg</title>
<meta http-equiv="Content-Type" content="text/html; charset=Windows-1251">
<meta http-equiv="Content-Style-Type" content="text/css">
<style type="text/css"><!--
body {
  margin: 5px 5px 5px 5px;
  background-color: #ffffff;
/* ========== Text Styles ========== */
hr { color: #000000}
body, table, span.rvts0 /* Font Style */
 font-size: 12pt;
 font-family: 'Times New Roman', 'Times', serif;
 font-style: normal;
 font-weight: normal;
 color: #000000;
 text-decoration: none;
a.rvts1, span.rvts1
 color: #0000ff;
 text-decoration: underline;
a.rvts2, span.rvts2
 font-family: 'Tahoma', 'Geneva', sans-serif;
 color: #0000ff;
a.rvts3, span.rvts3
 color: #4cd2ff;
a.rvts4, span.rvts4
 font-style: italic;
 color: #4cd2ff;
a.rvts5, span.rvts5
 color: #0000ff;
a.rvts6, span.rvts6
 color: #74ff42;
a.rvts7, span.rvts7
 color: #0000ff;
a.rvts8, span.rvts8
 color: #66ff34;
a.rvts9, span.rvts9
 color: #0000ff;
a.rvts10, span.rvts10
 color: #3cff39;
span.rvts11
 color: #d40dc0;
a.rvts12, span.rvts12
 color: #8000ff;
span.rvts13
 color: #8000ff;
a.rvts14, span.rvts14
 color: #a2ff4b;
a.rvts15, span.rvts15
 font-style: italic;
 color: #a2ff4b;
span.rvts16
 color: #ff0000;
a.rvts17, span.rvts17
 color: #0000ff;
a.rvts18, span.rvts18
 color: #804000;
a.rvts19, span.rvts19
 font-weight: bold;
 color: #804000;
/* ========== Para Styles ========== */
p,ul,ol /* Paragraph Style */
 text-align: left;
 text-indent: 0px;
 padding: 0px 0px 0px 0px;
 margin: 0px 0px 0px 0px;
--></style>
</head>
<body>
<p><span class=rvts11>sdafksjdkl</span> fjas</p>
<p> sa kdf&nbsp; <a class=rvts15 href="http://www.google.com">jklasdj</a> f;asjd</p>
<p><br></p>
<p>asdf asdf <a class=rvts19 href="http://www.mail.com">asdf</a> asdf asdf asdf</p>
</body></html>
При конвертации из ХТМЛ формата в РВФ теряется форматирование гиперссылок, то есть не зависимо от выбранного цвета/шрифта и т.д. все стает стандартным (синим).
Так же существуют другие проблемы с сохранением форматирование при конвертации. Такие как сложное форматирование, оно просто все улетает.
Или например
1я строка
2я строка
после сохранения в ХТМЛ формат и обратной конвертации в РВФ (из ХТМЛ) будте выглядеть. (то есть появится отступ во второй строке)
1я строка
2я строка
Thank you, Sergey!
Darken
Post by Darken »
Или например
1я строка
2я строка
1я строка
__2я строка <- во второй строке отступ возникает (выше пробелы не сохранились)
TrvHtmlImporter does not support CSS. There are some limited support of CSS saved by TRichView itself, but it does not include hyperlinks, sorry.
The solution is using TrvHtmlViewImporter.
TrvHtmlImporter will not be improved, sorry. We plan to implement TRichView.LoadHtml from scratch, not based on existing importers.
