Tdbrichviewedit event
jota
Post by jota »
Hi.
I´m using the onchange event of a tdbrichviewedit component to detect a change in the number of styles.
It would be enough to know if the number of styles has changed, just before leaving the component. Is there some event where this can be done?
Do you mean changing TextStyles, ParaStyles, and ListStyles?
You can compare count with previously saved value in OnExit event.
Some useful info.
If styles are added as a result of:
- RVF insertion
- RTF loading or insertion
- operation with StyleTemplates
- changing keyboard language with rvoAutoSwitchLang in EditorOptions,
TRichViewEdit.OnAddStyle occurs.
If you use RichViewActions, if styles are added by RichViewActions, TRVAControlPanel.OnAddStyle occurs.
jota
Post by jota »
Hello
My code is as follows
If I leave the "TDBRichViewEdit" component by clicking the mouse on a node in the "TTreeView" component; the variable "tnNodAux" stores information for that node.
But I need to save the selected node just when leaving the "TDBRichViewEdit"
# TDBRichViewEdit NoteEdit. OnExit event
procedure TSDIAppForm.NoteEditExit(Sender: TObject);
  tnNodAux: TTreeNode; // Node (auxiliar)
  # TTreeView TreeOpc
  tnNodAux := TreeOpc.Selected;
  # TRVStyle NoteEditStyles
  tnNodAux.ImageIndex := NoteEditStyles.TextStyles.Count;
Thanks in advance
If you just need to save changes, you can call:
if DataSet.State in [dsEdit, dsInsert] then
    DataSet.Post;
jota
Post by jota »
hello
My problem is this.
I have a TTreeView component. Selecting a node, the focus goes to a TDBRichViewEdit component.
Just before leaving the TDBRichViewEdit component (eg by clicking the mouse on another node in TTreeView component), I need to store 'tnNodAux: = TreeOpc.Selected;'.
If I do it in the OnExit event in TDBRichViewEdit component, variable stores the last node selected with the mouse.
I need to store the TTreeView selected node just in time before leaving the component TDBRichViewEdit
You switching records in your own code (probably in TreeView.OnSelect)?
So you can call all necessary additional code in the same event, not in OnExit/OnEnter.
