[Example] How to replicate table rows
The function below replicates rows of the current table in rve, Count times. New rows are added to the end of the table.
Heading rows are not replicated.
The function replicates the table structure, cell and row attributes, default text and paragraph styles in cells. It does not replicate cells contents.
This operation is undoable.
function ReplicateRowsInCurrentTable(rve: TCustomRichViewEdit; Count: Integer): Boolean;
var Table: TRVTableItemInfo;
    StartRow, i, r, c, RowCount, Data, SourceRow, DestRow: Integer;
    DestCell, SourceCell: TRVTableCellData;
  Result := rve.GetCurrentItemEx(TRVTableItemInfo, rve, TCustomRVItemInfo(Table));
  if not Result then
  if table.CanUseHeadingRowCount then
    StartRow := Table.HeadingRowCount
    StartRow := 0;
  RowCount := Table.RowCount-StartRow;
  Result := RowCount>0;
  if not Result then
  Result := rve.CanChange;
  if not Result then
  rve.BeginUndoGroup(rvutModifyItem);
  rve.SetUndoGroupMode(True);
  rve.BeginItemModify(Table.GetMyItemNo, Data);
    table.InsertRows(table.RowCount, RowCount*Count, -1, False);
    for i := 0 to Count-1 do
      for r := 0 to RowCount-1 do begin
        SourceRow := StartRow+r;
        DestRow := StartRow+(i+1)*RowCount+r;
        for c := 0 to Table.ColCount-1 do begin
          SourceCell := Table.Cells[SourceRow,c];
          if (SourceCell<>nil) then begin
            if (SourceCell.ColSpan>1) or (SourceCell.RowSpan>1) then
              Table.MergeCells(DestRow,c, SourceCell.ColSpan, SourceCell.RowSpan, False);
            DestCell := Table.Cells[DestRow,c];
            DestCell.AssignAttributesFrom(SourceCell, True, 1, 1);
            DestCell.Clear;
            DestCell.AddNL('', SourceCell.GetFirstTextStyleNo(True), SourceCell.GetFirstParaStyleNo);
        table.Rows[DestRow].PageBreakBefore := table.Rows[SourceRow].PageBreakBefore;
        table.Rows[DestRow].KeepTogether := table.Rows[SourceRow].KeepTogether;
        table.Rows[DestRow].VAlign := table.Rows[SourceRow].VAlign;
     table.DeleteEmptyRows;
     table.DeleteEmptyCols;
    rve.SetUndoGroupMode(False);
    rve.EndItemModify(Table.GetMyItemNo, Data);
    rve.Change;
The function returns True on successful replication.
Possible reasons for a failure:
- the current item is not a table
- no non-heading rows in the table
- text protection or read-only mode
Example
Before:
After calling ReplicateRowsInCurrentTable(RichViewEdit1, 10):
