Error sending massive commands
friman
Post by friman »
I am trying send massive commands to allowed guids, executing the follow sentences
Cmd := TRVCmd.Create;
  Cmd.Cmd := _CMD_USER_STATUS;
  with Cmd.Params.Add  do begin
    Name      := 'Status';
    ParamType := rvptString;
    Value     := Status;
  for I := 0 to Length(AllUsers)-1 do begin
     RVCamSender1.SendCmd(Cmd, AllUsers[i].GUID, '');
     RVCamSender1.WaitForSendCmd;
The first normal, the second return error. Is there some suitable way to do that?
SendCmd frees TRVCmd object, so you cannot use the same object for sending multiple commands.
Create a new TRVCmd object for each call of SendCmd
