[Example] How to move caret to the paragraph
A very simple example: how to move caret to the beginning of the n-th paragraph
procedure GoToParagraph(rve: TCustomRichViewEdit; ParagraphIndex: Integer);
var i: Integer;
  for i := 0 to rve.ItemCount-1 do begin
    if rve.IsParaStart(i) then
      dec(ParagraphIndex);
    if ParagraphIndex<0 then begin
      rve.SetSelectionBounds(i, rve.GetOffsBeforeItem(i), i, rve.GetOffsBeforeItem(i));
      rve.Invalidate;
Call:
GoToParagraph(RichViewEdit1, 7);
ParagraphIndex is zero-based.
Moving to the end of the current line. This function used some undocumented methods
uses CRVFData, RVERVData;
procedure GoToEndOfLine(rve: TCustomRichViewEdit);
var DItemNo, DOffs, ItemNo, Offs: Integer;
    RVData: TRVEditRVData;
  RVData := TRVEditRVData(rve.TopLevelEditor.RVData);
  DItemNo := RVData.CaretDrawItemNo+1;
  while (DItemNo<RVData.DrawItems.Count) and not RVData.DrawItems[DItemNo].FromNewLine do
    inc(DItemNo);
  dec(DItemNo);
  DOffs := RVData.GetOffsAfterDrawItem(DItemNo);
  RVData.DrawItem2Item(DItemNo, DOffs, ItemNo, Offs);
  RVData.SetSelectionBounds(ItemNo, Offs, ItemNo, Offs);
Moving to the end of the current paragraph
procedure GoToEndOfPara(rve: TCustomRichViewEdit);
var ItemNo, Offs: Integer;
  rve := rve.TopLevelEditor;
  ItemNo := rve.CurItemNo+1;
  while (ItemNo<rve.ItemCount) and not rve.IsParaStart(ItemNo) do
    inc(ItemNo);
  dec(ItemNo);
  Offs := rve.GetOffsAfterItem(ItemNo);
  rve.SetSelectionBounds(ItemNo, Offs, ItemNo, Offs);
Moving to the end of the document
procedure GoToEndOfDoc(rve: TCustomRichViewEdit);
  ItemNo := rve.ItemCount-1;
