Add Markdown to TRichview
Tony
Post by Tony »
TRichview is Great work, can you add Markdown support to TRichView? thanks. :D
Tony
What is Markdown?
Tony
Post by Tony »
Sergey Tkachenko wrote:What is Markdown?
Please google search "Markdown", it is a lightweight tag language, very populer recently years
Ok, I found it. But it's not too widespread format, isn't it? Probably, the simplest solution is using some converter converting it to/from HTML or RTF.
