Default Printer not exist
cychia
Post by cychia »
if the default printer is set to a printer which no longer exist, I will get the following exception from RVRuler:
"Printer selected is not valid"
Then, after that I cannot access the Page Setup, Print Preview & Print.
Why?
Page Setup & Print Preview shouldn't depend on printer setting for display right?
All these actions depend on the chosen printer.
Print preview relies on page size and printer resolution.
Page setup reads from the printer a list of available page sizes and paper sources.
Please contact the ruler author (Pieter Zijlstra, see his email in Ruler.pas) about the exception.
Pieter Zijlstra
Post by Pieter Zijlstra »
Since version 1.6, included in RichViewActions 1.33, RVRuler should not generate an exception when the default printer is not available. Which version are you using?
You can turn of the handling of the default printer by RVRuler by setting roAutoUpdatePrinterWidth and roUseDefaultPrinterWidth of RVRuler.Options to False.
cychia
How to show Page Setup without printer set?
Post by cychia »
How if there is no printer is set, but I still want to do Page Setup?
In RichViewActions, it's not possible.
