spell check
rellik
spell check
Post by rellik »
Здравствуйте, скажите, как можно локализировать(перевести на русский) форму проверки орфографии?
Please note that the forums language is English.
There is a special forum in Russian language for registered TRichView users. If you are a registered user, please send me a private message with information allowing me to find your order.
Or you can ask questions by email (richviewgmailcom).
As for your question about localization of spell checking forms.
1) If you use Express Spell Checker (TRvDxSpellChecker).
The spelling forms for this checker are designed by ourselves and included in the spelling package. However, they use cxGetResourceString() to get captions, so it is localized together with other DevExpress components.
2) If you use Addict spell checker, the components have UILanguage property. RichViewActions include RVAAddictLanguages unit that converts RichViewActions language to Addict's UILanguage.
3) If you use HunSpell, ASpell, LS Speller, the spelling form is designed by ourselves and included in the spelling package.
Please note that there are two spelling forms:
- classic spelling form TfrmRVSpell (RVSpellFrm unit)
- MS Word-style form TfrmRVSpellWord (RVSpellWordFrm unit)
(I assume that USERVTNT is not defined)
You can use OnSpellForm action to localize them. This event occurs before the form is displayed:
procedure TForm1.RVHunSpell1SpellForm(Sender: TRVHunSpell; Form: TRVHunSpellCustomSpell);
  Form.btnAdd.Caption := ...
  if Form is TfrmRVSpellWord then
    TfrmRVSpellWord(Form).btnUndoEdit.Caption := ...
Last edited by Sergey Tkachenko on Mon Nov 02, 2015 6:20 am, edited 3 times in total.
rellik
Post by rellik »
ok, sorry for russian. Thanks for answer.
