Template Page
chorao157
Template Page
Post by chorao157 »
It is possible to make a dynamic page according to the User Profile ?
Example :
Red marking = mandatory space.
I am not sure that I understand where is the problem.
Do you need to fix top coordinates of these sections, regardless of their length?
You can simple create a table (without borders) having a single column and the proper heights of cells.
Also, you may consider using headers and footers.
chorao157
Post by chorao157 »
I wanted to do as a report with pre-determined spaces.
You can insert empty a lines between these parts.
And set their LineSpacingType = rvlsLineHeightExact, and LineHeight = height of line.
