It is possible convert RVF format to HTML without a visual component into a form ?
thanks
Convert to HTML without a visual editor
Re: Convert to HTML without a visual editor
I am trying to use this approach to convert RTF text and images that are stored in a database to HTML without any user interface. After I load the RTF in the TRVReportHelper.RichView and call SaveHTMLToStream I get empty result.
Can you explain if my approach is possible or if there is another way to convert RTF stored in a database directly to HTML (stream) without user interface?
Regards,
Maikel
Regards,
Maikel
This method must work.
Make sure that you linked TRVReportHelper with some TRVStyle component:
RVReportHelper1.RichView.Style := RVStyle1;
