Using OnDrawStyleText with ScaleRichView
DavidRM
Post by DavidRM »
Is it possible to use the RVStyle.OnDrawStyleText event with SRV?
Are there special issues that have to be dealt with?
Thanks.
-David
Before SRV v7 - no.
In version 7 and newer - yes.
However, you cannot simply use TextOut or similar simple methods to draw text, because SRV positions each character manually.
You must use Draw method of a text style to draw text.
You can see the demo Demos\RVDemos\Assorted\Custom Draw\CustomDraw\
DavidRM
Post by DavidRM »
Ah, OK. I see I will need to update my SRV (I'm still in v6.1.3).
Thanks.
-David
