shrink a Image in TRichviewEdit
WLemmermeyer
Post by WLemmermeyer »
Hallo,
I use the stardard actions for my TRichViewEdit. I changed TrvActionInsertPicture.MaxImageSize to 650 px but this only scales down the image and don't reduce the size of a image.
Is it possible to shrink a image or get a Event like OnInsertImage (OnImportPicture is not fired) to shrik the image manually?!?
Best regards
Do you want to insert a modified image instead of stretched displaying?
WLemmermeyer
Sergey Tkachenko wrote:Do you want to insert a modified image instead of stretched displaying?
yes, this could be a solution.... how can I do this?
I'll add this option to RichViewActions in the next update.
Included in RichViewAction 6.5 (available for registered users), the event is called OnInserting
