How to dump all text to a string buf with CR+LF?
because i want to split it with CR+LF,not the item.
and,if get one string line,how to get each item of the line?
How to get all text?
In order to include picture names, you need to modify GetItemText from this unit ("or (rv.GetItem(ItemNo) is TRVGraphicItemInfo)" is added):
The same change must be done in GetItemText2.
PS: This example assumes that the picture text (which you want to insert in string) is stored in the item name (the first parameter of InsertPicture, can be read by GetItemTextA, changed by SetItemTextA).
But probably you want to insert "alternative text", stored in rvespAlt property (this property was specially added to store a text representation of image). In this case, text for images must be retrieved using GetItemExtraStrProperty method.
function GetItemText(rv: TCustomRichView; ItemNo: Integer): String;
if (rv.GetItemStyle(ItemNo)>=0) or (rv.GetItem(ItemNo) is TRVGraphicItemInfo) then
Result := rv.GetItemTextA(ItemNo)
else if rv.GetItem(ItemNo).GetBoolValue(rvbpAlwaysInText) then
Result := rv.GetItem(ItemNo).AsText(0, rv.RVData, rv.GetItemText(ItemNo), '', True, False)
Result := '';
