I am trying to stream live video from an IP camera module. I have successfully been able to use VCL Player to stream, using this URL:
rtsp//:192.168.1.10:554/rtsp_live0
What are the minimal components and their settings that I can use in RVMedia to have streaming with that URL? Thanks.
RTSP camera module streaming
':' should be moved, the correct URL is
rtsp://192.168.1.10:554/rtsp_live0
However, this is a local URL, isn't it? So we cannot test it.
RTSP requires FFmpeg or GStreamer. RVMedia uses them automatically, if they can be found. For example, FFmpeg can be downloaded from
http://www.trichview.com/resources/thir ... ffmpeg.zip
Copy 32-bit dlls to the folder of your application.
You can test using Demos\Cameras\FFmpeg\ demo.
rtsp Streaming
Thanks for your reply. Sorry, I mis-typed the URL. As you instructed, I copied all the FFmpeg dlls into the FFmpeg demo folder, but the demo does not display the video stream. Are there other settings that need to be set?
Thanks, Allan
Thanks, Allan
