XML and Meta tags
Hanno
XML and Meta tags
Post by Hanno »
Hi, just started using the "meta" property of XML and having some difficulty getting it to work. I would appreciate a small sample of adding a couple of meta tags and that can be saved and reloaded.
Never user it myself, but it seems that data are saved and loaded to RvXML.Meta.Value
