A problem with RVE.SearchText
IGDark
Post by IGDark »
I have a question - is there any way to search a text in TRichViewEdit from one position to another using SearchText. For example I need to find a specific text from one position in the component to another (to the end). What I mean is that I don't want RVE to search text cyclically. I want it to stop at the end. For example I have a block of text
Test1
Test2
Test1
Test3 <<---- starting position
Test1
I identify the starting position using SetSelectionBounds. And now I want to find "Test1" from this position up to the end. If I write
while CWnd.SearchText('Test1', [rvseoDown]) = true do
Then the component will find 3 occurrencies, but I need just one...
I would really appreciate your help!
Alex.[/img]
Currently, it's not possible to define where the search should stop.
The only way - checking if the found word is beyond the limit.
