How send/receive differents cameras?
friman
Post by friman »
Hello Seguey
The last issue is:
I am trying to send 2 or more cams from "sender" (managing differents rooms) adding second RVCamSender and coding something like
RVCamSender2.GUIDFrom:=FMyGUID;
RVCamSender2.ReceiverPort:=FMain.RVCamSender1.ReceiverPort;
RVCamSender2.ReceiverHost:=FMain.RVCamSender1.ReceiverHost;
RVCamSender2.Active:=True;
RVCamSender2.GUIDGroup:=RoomGUID;
RVCamSender2.SendMediaAccessRequest(RoomGUID);
on "receiver side" I did
RVCamReceiver1.Senders[0].VideoSenders.AddGUID(RoomGUID);
RVCamSender1.SendMediaAccessRequest(RoomGUID);
RVCamSender1.JoinGroup(AnsiStringToGUID(RoomGUID), False);
RVCamView.GUIDFrom:=RoomGUID;
RVCamView.VideoSource:=RVCamReceiver1;
So, it work fine if I open on "receiver" one room, but when open 2 the cameras feeds start to mix each to others.
What I did wrong? Or what suggestion you have in this case?
Thanks on advance
Unfortunately, it's quite difficult to implement multiple cameras working at the same time in the same mediaserver client.
We will solve this problem in the next update. A single TRVCamSender will be able to send video from multiple cameras, and the receiver will be able to distinguish them by indexes.
