2 pixel cropped when drawing into device context
lwinter
Post by lwinter »
when drawing the content of a RV edior into a device context (metafile), it looks as if it would print one or two pixels over the right and bottom.
Also, when right-justified, the plain text lines are printed two pixels too far to the right and are cropped, whereas custom-control-fields are correct.
It could be possible that those two may be related.
Is there anything in your RV data / code that may cause this?
This is how I call the painting:
// Draw all vector-like into given dc with transparent background.
procedure AARichViewEditControl.DrawToDC(deviceContext: HDC; rect: TRect);
    AARVData: AARichViewRVData;
    origin : TPoint;
    i : Integer;
    control: AARichViewCustomControl;
    AARVData := RVData as AARichViewRVData;
    AARVData.PaintToDC(deviceContext, rect);
    SetViewportOrgEx(deviceContext, rect.Left, rect.Top, @origin);
    for i := 0 to ControlCount - 1 do
        if (Controls[i] is AARichViewCustomControl) then
            control := Controls[i] as AARichViewCustomControl;
            control.PaintToDC(deviceContext);
        SetViewportOrgEx(deviceContext, origin.X, origin.Y, nil);
procedure AARichViewRVData.PaintToDC(hdc: HDC; rect: TRect);
    Canvas: TCanvas;
    r: TRect;
    origin: TPoint;
  SetViewportOrgEx(hdc, rect.Left, rect.Top, @origin);
  Canvas := TCanvas.Create;
  Canvas.Handle := hdc;
  r := rect;
  OffsetRect(r, -r.left, -r.top);
    PaintTo(Canvas, r);
  except
    on E: Exception do begin
  Canvas.Handle := 0;
  Canvas.Free;
  SetViewportOrgEx(hdc, origin.X, origin.Y, nil);
Thank you for your help!
-- Lutz
Try to draw in bitmap, does the problem persist?
