RvHtmlImporter and Delphi 2006
keith
Post by keith »
Is there a Delphi 2006 version of RVHTMLImporter?
Thanks,
Keith
keith
Error on install of RVHTMLImporter in D2006
Post by keith »
Thanks for answering my post so quickly, unfortunately I am having a new problem. When I try to install RVHTMLImporter into Delphi 2006 I get the following error when I click on Install for the rvhtml2006.bdsproj package:
Cannot load package 'RVPkg2006.' It contains unit 'RVXPTheme,' which is also contained in package 'RVPkgD9'
Thanks,
Keith
Did you install RVPkgD9 in Delphi2006?
You should not, the package for Delphi2006 is RVPkg2006.bdsproj
keith
Not sure how the D9 version got installed
Post by keith »
Somehow the D9 version of TRichView was installed, and removing it manually and installing RVHTML again worked.
Thanks,
Keith
