How to prevent a table cell to get focus?
dudubaiao
Post by dudubaiao »
I'm filling some cells of a table with text and other cells with TEdits.
I just want to avoid that the user sets the focus on the text cells.
Search on RVItem unit I found this:
TRVItemBoolPropertyEx = (rvbpPrintToBMP, rvbpJump,
rvbpAllowsFocus,rvbpHotColdJump,
rvbpXORFocus, rvbpHotCold, rvbpActualPrintSize)
But I could not know if I can use this with table cells.
This property has different meaning (this "focus" is a dotted rectangle that TRichView (not TRichViewEdit) can draw around some items, such as hyperlinks).
You can use table.OnCellEditing event to move caret to another cell.
For example, this code does not allow to put caret in cells of the first column:
procedure TForm3.CellEditing(Sender: TRVTableItemInfo; Row, Col: Integer;
  Automatic: Boolean; var AllowEdit: Boolean);
  AllowEdit := Col>0;
Table events are not saved in RVF files (and are lost on copy-pasting). To prevent this problem, this event should be assigned in OnItemAction event:
procedure TForm3.RichViewEdit1ItemAction(Sender: TCustomRichView;
  ItemAction: TRVItemAction; Item: TCustomRVItemInfo; var Text: String;
  RVData: TCustomRVData);
  if (ItemAction=rviaInserting) and (Item.StyleNo=rvsTable) then
    TRVTableItemInfo(Item).OnCellEditing := CellEditing;
