i can't find beta version with new recording comp
also need help code for save sound as valid wave file form onsound event
beta version !!
Re: beta version !!
Beta version is available for registered RVMedia users.
If you ordered RVMedia, please send me a private message with details allowing me to find your order (for example, which email address was used in the order).
Also, you can run the setup of the full version of RVMedia, and on the page where the setup checks for updates, select "check for stable and beta versions".
For sound recording, it's simpler to use a new TRVSoundPlayer component (which can not only play sound but also record sound to a file)
PS: We are planning to upload a beta version update soon, when we fix the problem described here: http://www.trichview.com/forums/viewtop ... =17&t=8837)
