Is there any support for the PDF/A-3 File Format inside the Report Workshop?
I need to know if it is possible to embedd files direktly via Report WorkShop to the PDF/A-3 Files of if I would need an external library.
Thank you.
Mr. Bean
Question about Report Workshop
Re: Question about Report Workshop
Report Workshop allows designing report templates (in TRichViewEdit/TSRichViewEdit) and generating reports from them (in TRichViewEdit/TSRichViewEdit as well).
It does not include new procedures for exporting: reports are exported using the same methods as normal TRichView documents.
So you need an external library to export to PDF.
