Insert image from a copy and paste
alexandreq
Post by alexandreq »
Hello
If I copy a bmp image and paste it into my Trichview, is it pasted as bmp or jpge?
If it is pasted as bmp, is there any way to paste it as jpge?
Regards
Re: Insert image from a copy and paste
There is no standard Clipboard format for Jpegs, so the copied image will be inserted as a bitmap.
The only way to paste JPEG to RichViewEdit is copying a JPEG file (for example, from Explorer).
Here is a function that pastes bitmap as JPEG:
function PasteBitmapAsJpeg(rve: TCustomRichViewEdit): Boolean;
  bmp: TBitmap;
  jpg: TJPEGImage;
  Result := Clipboard.HasFormat(Windows.CF_BITMAP);
  bmp := TBitmap.Create;
    bmp.Assign(Clipboard);
    jpg := TJPEGImage.Create;
    jpg.Assign(bmp);
    bmp.Free;
  rve.InsertPicture('', jpg, rvvaBaseline)
I think it's not a very good idea to paste all bitmap images as JPEGs. JPEGs are good for photos, but not good for screenshots, because they use lossy compression. However, if you want it, you can implement OnPaste event:
procedure TForm3.SRichViewEdit1Paste(Sender: TCustomRichViewEdit;
  var DoDefault: Boolean);
  DoDefault := not PasteBitmapAsJpeg(Sender);
