Code for table
VicFan
Code for table
Post by VicFan »
I am trying to figure out code for a table and tried the following:
	TRVTableItemInfo * table;
	table = new TRVTableItemInfo(1, 3, RichView1->RVData);
	table->Cells[0][0]->Clear();
	table->Cells[0][0]->AddNL("One", 1, 1);
	RichView1->AddItem("A", table);
	table->Cells[0][1]->Clear();
	table->Cells[0][1]->AddNL("Two", 1, 1);
	RichView1->AddItem("B", table);
	table->Cells[0][2]->Clear();
	table->Cells[0][2]->AddNL("Three", 1, 1);
	RichView1->AddItem("C", table);
	RichView1->Format();
But what I am getting is for every column in the table, I get that many identical rows. For example, the above gives three identical rows, since I had a 3 columns.
How do I get a table with just one row from the above pattern, or something similar?
Re: Code for table
You add the same table object 3 times (each time when you call AddItem).
As a result, you can see 3 identical tables, and a crash at exit (when TRichView tries to free this table 3 times).
Just add this table one time:
	RichView1->AddItem("ABC", table);
