Supersrcipt
assantos
Supersrcipt
Post by assantos »
How can i format superscript font in code
Use VShift property of text style.
For example, you can find a modified "Editor2" demo with "subscript" and "superscript" commands here:
http://www.trichview.com/support/files/reditss.zip
jonjon
Post by jonjon »
Well, that is a nice "workaround" but not a real solution. Imagine the user selects the whole text to change the size, then it will also change the super/sub scripts' sizes. Besides, that won't be correctly exported in HTML with the <sup> and <sub> tags.
Are you planning to implement those as native items, perhaps internally using the VShift property to save time ?
Regards,
John.
Yes, it's planned for future, as a new property of text style.
But even the current solution will be exported to HTML as <sup> and <sub>
jonjon
Post by jonjon »
Sergey Tkachenko wrote:But even the current solution will be exported to HTML as <sup> and <sub>
Oh, that's nice to hear! So I guess every stone is in place for the implementation then ;) Looking forward for that feature.
Regards,
John.
