TRVStyleTemplateCollection : SaveToStreamRVST, LoadFromStreamRVST
Vitalii
Post by Vitalii »
can you add something like that in TRVStyleTemplateCollection?
function TRVStyleTemplateCollection.SaveToStreamRVST(Stream: TStream; Units: TRVStyleUnits): Boolean;
ini: TMemIniFile;
Result := False;
ini := TMemIniFile.Create(Stream, TEncoding.UTF8);
ini.EraseSection(STYLETEMPLATEINISECTION);
SaveToINI(ini, STYLETEMPLATEINISECTION);
ini.WriteInteger(STYLETEMPLATEINISECTION, RVINI_UNITS, Ord(Units));
ini.UpdateFile;
ini.Free;
Result := True;
except
function TRVStyleTemplateCollection.LoadFromStreamRVST(Stream: TStream; Units: TRVStyleUnits; ARVStyle: TRVStyle = nil): Boolean;
ini: TMemIniFile;
FileUnits: TRVStyleUnits;
Result := False;
LoadFromINI(ini, STYLETEMPLATEINISECTION);
FileUnits := TRVStyleUnits(ini.ReadInteger(STYLETEMPLATEINISECTION,
RVINI_UNITS, Ord(rvstuPixels)));
UpdateReferences;
ini.Free;
if FileUnits <> Units then
if ARVStyle = nil then
ARVStyle := FOwner as TRVStyle;
ConvertToDifferentUnits(ARVStyle, FileUnits, Units);
Result := True;
except
For now I add this code manually in every engine update. It would be great to see this methods in next release of TRichView :)
Re: TRVStyleTemplateCollection : SaveToStreamRVST, LoadFromStreamRVST
Ok, I'll add it in the next update.
I did not know that TMemIniFile can be linked to a stream. I checked, this feature was added in RAD Studio 10.3
Vitalii
Post by Vitalii »
Thank you, Sergey!
work correctly with 10.2, don’t know for earlier versions
It's strange. In 10.2 source, I can see 3 constructors for TMemIniFile, all of them has FileName, not Stream parameter.
Vitalii
"ini.UpdateFile" code required!
Post by Vitalii »
method SaveToStreamRVST does not save data in ini file. To save the data, at the end of the operation you need to call the method "ini.UpdateFile":
ini.UpdateFile; // <<<----- THIS CODE REQUIRED
ini.Free;
Thank you! It is fixed in TRichView v18.5.1
