<< Click to display table of contents >> TrvActionFind.FindText |
A string to initialize the find dialog.
property FindText: TRVUnicodeString;
If value of this property is not empty, it is assigned to the find dialog's FindText when a search is started. Otherwise, the dialog is initialized with text selected in the target editor.
Default value
'' (empty string)
