TCustomSRVGraphicControl
TSRVGraphicControl is the base class for lightweight SRVControls.
Unit SRVControl;
Syntax
TCustomSRVGraphicControl = class(TGraphicControl);
Hierarchy
TObject
TPersistent
TComponent
TControl
TGraphicControl
Properties and events
Public properties:
Property
Type
Default value
Meaning
AutoDarkMode
Boolean
True
If True, and the control is inserted in a dark-mode editor (TSRichViewEdit or TRichView), luminance of all colors is inverted.
Otherwise, DarkMode property is used.
DarkMode
Boolean
False
If True, luminance of all colors are inverted.
This property is used only if the control is not inserted in an editor, or if AutoDarkMode = False.
DrawOnPrint
Boolean
True
if True, this control will be printed
readonly IsMouseDown
Boolean
Read-only. Returns True if the user pressed the left mouse button above the control.
readonly MouseIn
Boolean
Read-only. Returns True, if the mouse pointer is above the control
Public events:
•OnMouseEnter, OnMouseLeave (TNotifyEvent) occur when the mouse pointer enter/leaves the control.
Protected properties:
Property
Type
Default value
Meaning
protected Alignment
TAlignment
taLeftJustify
Text alignment. RTL BiDiMode inverts left and right alignments
protected SkinManager
TSRVSkinManager
A link to a skin manager component.
protected SkinSchemeIndex
Integer
0
Index in a scheme in SkinManager.CurrentSkin (a scheme depends on the control type)
Additionally, for Delphi versions prior to 2009, this control introduces Unicode Caption (of TRVUnicodeString) type to use instead of ANSI string Caption (so Caption is Unicode in all versions of Delphi)
Inherited components
SRVLabel TSRVLabel
srvpaintbox TSRVPaintBox
