TSRichViewEdit.ConvertSRVtoRV
Converts client coordinates in this TSRichViewEdit component to client coordinates of ActiveEditor.
function ConvertSRVtoRV(p: TPoint; var bInTextArea, bInLeft, bInPageArea: Boolean): TPoint;
Input parameters:
p – coordinates relative to the top left corner of TSRichViewEdit's window.
Output parameters:
bInTextArea – True if p is inside of some page's content area.
bInLeft – True if p is to the left of some page (in the "line selection" area).
InPageArea – True if p is inside of some page's area (above content or above margins).
Return value:
coordinates relative to the top left corner of ActiveEditor.
See also:
•ConvertRVToSRV
Example:
This code assigns text of the item at the position of the mouse pointer to Label1.Caption
// OnMouseMove event
procedure TForm3.SRichViewEdit1MouseMove(Sender: TObject;
  Shift: TShiftState; X, Y: Integer);
var pt: TPoint;
  RVData: TCustomRVFormattedData;
  InPageArea, InLeftArea, InTextArea: Boolean;
  ItemNo, Offs: Integer;
  pt := SRichViewEdit1.ConvertSRVtoRV(Point(X, Y), InTextArea,
    InLeftArea, InPageArea);
  if InTextArea then begin
    pt := SRichViewEdit1.ActiveEditor.ClientToDocument(pt);
    SRichViewEdit1.ActiveEditor.GetItemAt(pt.X, pt.Y,
      RVData, ItemNo, Offs, True);
    if ItemNo>=0 then
      Label1.Caption := RVData.GetItemText(ItemNo)
    else // in page, but not in item
      Label1.Caption := '';
    end
  else // not in page
