TSRichViewEdit.FixMarginsMode
Specifies how to work with too small margins (less than the printer supports).
type
  TSRVFixMarginsMode = (srvfmmAutoCorrect, srvfmmIgnore);
property FixMarginsMode : TSRVFixMarginsMode;
This property is similar to TRVPrint's property of the same name.
Mode
Meaning
srvfmmAutoCorrect
Minimal supported margins are used (if the left and/or the top margin were too small, the output is moved to the right and/or down)
srvfmmIgnore
The specified values of margins are used (document may be cropped)
Default value:
srvfmmAutoCorrect
See also
•PageProperty.PrintableAreaPen
