TSRichViewEdit.ScrollToItem
Scrolls to make the specified item visible. Optionally moves the caret to this item.
function ScrollToItem(RVData: TCustomRVFormattedData; ItemNo: Integer;
  SetCaret: Boolean = True; ToItemEnd: Boolean = False;
  ToItemCenter: Boolean = False; SmoothScroll: Boolean = False): Boolean;
The item location
RVData is a document (RichViewEdit.RVData, table cell, or cell inplace editor's RVData), ItemNo is an index of item in this document.
Moving the caret
If SetCaret=True, the method not only scrolls the window, but also moves the caret to the specified item. The caret is moved either to the beginning of this item (if ToItemEnd=False) or to the end of it (if ToItemEnd=True).
Scrolling
If ToItemCenter=False, the method scrolls so that the item top is shown at the top of the editor window,
If ToItemCenter=True, the method scrolls so that the item middle is shown at the middle of the editor window.
If SmoothScroll = True, a smooth scrolling effect is applied.
See also:
•ScrollToCaret, ScrollCaretToCenter
