<< Click to display table of contents >> TSRVPageScroll.OnDrawPageNumber |
Allows a custom drawing of page numbers.
type
TPSDrawPageNumberEvent = procedure (Sender: TObject; Canvas: TCanvas;
const R: TRect; PageNo : Integer; isSelect : Boolean) of object;
property OnDrawPageNumber: TPSDrawPageNumberEvent;
By default, page numbers are displayed if PageNoVisible=True.
They are displayed in the location specified in AlignText, drawing using BackgroundTextColor and PageNoFont properties.
If this event is assigned, the default drawing is not performed.
Canvas – canvas where to draw.
R – location of the page number, calculated according to AlignText and PageNoFont.
PagNo – page number to draw.
isSelect specifies whether this page is highlighted.
