TSRVViewProperty.MainPen
A pen for drawing lines between the main document and the header and the footer, when the main document (TSRichViewEdit.RichViewEdit) is being edited.
type
  TSRVMainPen = class (TPen);
property MainPen: TSRVMainPen;
The color of this pen is also used for drawing border around the main document label, see Texts.
In Delphi XE2 or newer, if a system color is specified for MainPen.Color, and custom styles are applied, then a corresponding style color is used instead.
Default value:
1, psClear, $00CA784B (invisible line)
See also:
•HeaderPen
•FooterPen
