TSRichViewEdit.FindPriorHyperlink
Top  Previous  Next
Finds the location of the previous hyperlink.
function FindPriorHyperlink(var RVData: TCustomRVData;
  var ItemNo: Integer): Boolean;
The search can be limited to the specified range of coordinates, see RangeSearch.
Input parameters:
RVData, ItemNo – starting position for the search. The search starts from the previous item. RVData is a document (RichViewEdit.RVData, table cell, or cell inplace editor's RVData; if the cell is edited, it must be an inplace editor's RVData), ItemNo is an index of item in this document.
Output parameters:
RVData, ItemNo – position of the found hyperlink. Valid only if the method returns True.
Return value:
True if found.
See also:
FindNextHyperlink
PriorCurHyperlink
FindPriorCheckpoint
FindPriorItem
ScaleRichView © Ilya Zelensky & Sergey Tkachenko
