TSRichViewEdit.FindPriorItem |
Top Previous Next |
Finds the location of the next item of the specified styles (types). function FindPriorItem(StyleNo: array of Integer; var RVData: TCustomRVData; var ItemNo: Integer) : Boolean; The search can be limited to the specified range of coordinates, see RangeSearch. Input parameters: StyleNo – a list of styles (types) for searching. RVData, ItemNo – starting position for the search. The search starts from the previous item. RVData is a document (RichViewEdit.RVData, table cell, or cell inplace editor's RVData; if the cell is edited, it must be an inplace editor's RVData), ItemNo is an index of item in this document. Output parameters: RVData, ItemNo – position of the found item. Valid only if the method returns True. Return value: True if found. Example: var RVData: TCustomRVData; ItemNo: Integer; ... // searching for the last image in the document RVData := SRichViewEdit1.RichViewEdit.RVData; ItemNo := SRichViewEdit1.RichViewEdit.ItemCount; if SRichViewEdit1.FindPriorItem([rvsPicture, rvsHotPicture, rvsBullet, rvsHotspot], RVData, ItemNo) then ... See also: |
