TSRichViewEdit.FindNextCheckpoint
Finds the location of the next checkpoint.
function FindNextCheckpoint(var RVData : TCustomRVData;
  var ItemNo : Integer; CheckRaiseEvent : Boolean) : Boolean;
Unlike TCustomRichView's methods for checkpoints enumeration, this method correctly processes checkpoints in table cells.
The search can be limited to the specified range of coordinates, see RangeSearch.
Input parameters:
RVData, ItemNo – starting position for the search. The search starts from the next item. RVData is a document (RichViewEdit.RVData, table cell, or cell inplace editor's RVData; if the cell is edited, it must be an inplace editor's RVData), ItemNo is an index of item in this document.
CheckRaiseEvent – if True, searches only for checkpoints with "raise event" flag.
Output parameters:
RVData, ItemNo – position of the found checkpoint. Valid only if the method returns True.
Return value:
True if found.
See also:
•FindPriorCheckpoint
•NextCurCheckpoint
•FindNextHyperlink
•FindNextItem
