TSRichViewEdit.FindNextHeading
Finds the location of the next heading.
function FindNextHeading(var RVData: TCustomRVData;
  var ItemNo: Integer): Boolean;
The search can be limited to the specified range of coordinates, see RangeSearch.
Heading is a paragraph with OutlineLevel property > 0.
Input parameters:
RVData, ItemNo – starting position for the search. The search starts from the next item. RVData is a document (RichViewEdit.RVData, table cell, or cell inplace editor's RVData; if the cell is edited, it must be an inplace editor's RVData), ItemNo is an index of item in this document.
Output parameters:
RVData, ItemNo – position of the found item. Valid only if the method returns True.
Return value:
True if found.
See also:
•FindPriorItem
•NextCurItem
•FindNextCheckpoint
•FindNextHyperlink
