TSRichViewEdit.ReturnToNote
Ends editing a note's Document and moves the caret to the location of this note in the main document.
function ReturnToNote(SmoothScroll: Boolean = False): Boolean;
This method does nothing if a note is not being edited (i.e. when ActiveEditor<>RVNote).
When the caret is moved, the main document becomes active (ActiveEditor becomes equal to RichViewEdit).
If SmoothScroll = True, a smooth scrolling effect is applied.
Return value:
True if the caret was moved successfully
See also:
•StartEditNote
•Footnotes and endnotes
