TSRichViewEdit.StartEditNote
Begins editing the Document of the specified note or a text box item.
function StartEditNote(RVData: TCustomRVFormattedData;
  ItemNo: Integer; ScrollToNote: Boolean = True;
  SmoothScroll: Boolean = False): TRichViewEdit;
RVData and ItemNo must define the location of a note item. The following item types are supported:
•footnotes (TRVFootnoteItemInfo)
•endnotes (TRVEndnoteItemInfo)
•sidenotes (TRVSidenoteItemInfo)
•text box items (TRVTextBoxItemInfo)
This method changes value of ActiveEditor property (it becomes equal to RVNote).
If ScrollToNote=True, the method scrolls the control to show the edited note. If SmoothScroll = True, this scrolling is smooth.
Return value:
ActiveEditor if succeed. Nil if RVData and ItemNo do not define a location of a note or a text box item.
See also:
•StartEditing
•ReturnToNote
•Footnotes and endnotes
