TSRVPrint.OnSendingToPrinter
Occurs on printing.
type
  TSRVPrintingEvent = procedure(Sender: TSRichViewEdit;
    PageCompleted, FrameCompleted: Integer;
    Step:TRVPrintingStep) of object;
property OnSendingToPrinter: TSRVPrintingEvent;
This event is called by the printing methods.
The main printing methods are Print and PrintPages. Initially, they call this event with the following parameters: (SRichViewEdit, 0, 0, rvpsStarting). Then they call this event after printing each frame (non-poster modes assume one frame per page), with Step=rvpsProceeding. Finally, they call it with the parameters: (SRichViewEdit, 0, 0, rvpsFinished).
PageCompleted (index of page containing the completed frame, from 1) and FrameCompleted (index of the completed frame, from 1) are used if Step=rvpsProceeding.
See also:
•TSRichViewEdit.OnPrinting
